It is currently Wed Aug 06, 2025 4:48 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Tue Jan 20, 2009 7:58 pm
Yes, flooding everything while it is in place generally works out well.
I will say that of the few classical rosettes i have done, i have a much better time of it inlaying and glueing just the tiles first, then routing for the wheat/rope/purfling lines, kissing the edges of the tiles with the bit. Pretty much the same method we are talking about for wood ring rosettes.
If you have it looking good all layed up dry, flood away.
Jordan Aceto
Ithaca, NY
PostPosted: Thu Jan 22, 2009 8:15 am
Location: Between Bordeaux and the Atlantic. S.W.France
Thanks to everyone who contributed to this thread. I wish I'd thought about Todd Stock's suggestion of making a dummy at the same time, but it was half done by then. Next time...
I basically followed Shane's advice of inlaying the ring first, using Titebond and then cutting the grooves for three strips of veneer inside and out and flooding these with CA. I cut these two channels with a 1/16" dia. Stewmac downcut bit. I cut a trial channel in a piece of scrap and adjusted my veneers to fit. The thickness of the black veneers seems to vary in the finished rosette. I think the reason for this is that when I cut the two channels, the Titebond burned onto the bit and the resulting channels were a bit wider than the trial. Because of the added difficulty of inlaying veneers and trying to get a continuous ring without a visible join, I didn't notice that the groove was a bit too wide. The CA filled up the gaps and makes it look as if the black veneer varies in thickness. You can also see the joins if you look for them , even so, I'm fairly satisfied with this one. The next one should be perfect. ;) I'll perhaps make a Wells/Karol jig before then though.
Click on the pics for a better image.
PostPosted: Thu Jan 22, 2009 8:44 am
Looks pretty darn good to me. The joints aren't to visable like you said. I wonder if they were back cut if that would help any? Or if one could match them up with the grain would help hide them. Or maybe with light color wood there is just no getting away with hiding them.
Nice, the whole thing looks great & the miters blend right in, you really have to look for a while to spot them. The little bit of width variation on the black lines doesnt bother me at all.
I have that same stewmac jig, and i tapped out two holes in the base of a laminate trimmer in order to get away from the dremel, dremels have those sloppy bearings that can cause jumpy cuts.
The moral is, your rosette looks really good.
Jordan Aceto
Ithaca, NY
Users browsing this forum: Bing [Bot] and 18 guests
